DSP 4000
Home Forums Products Rackmount DSP 4000
    • #107659
      Jinglefactory
      When I power up my DSP 4000:
      Problem in internal Ram
      Bad checksum
      continue
      What's that…????
    • #121610
      It means what it says – bad checksum in internal ram.
      You can fix this with "fix internal" on the <setup> <service> menu. Look around p2-23 in the UM for more info.
      If it comes back, this will be a sign that the internal battery is fading. These last about 10 years, so the time could be right. If it is, you can buy one from the Eventide Store. The battery is built into the memory chip, so they are not cheap.
      http://eventidestore.com/40seupandop.html
      You should copy all User Presets to a card before changing the battery – in fact you should do it immediately, in cased the battery weakens quickly.
    • #121611
      Jinglefactory
      Thanx
