DSP 7000 noise problem
Home Forums Products Rackmount DSP 7000 noise problem
    • #112313
      PPNN
      Hi – I bought one of these units second hand but unfortunately on delivery discovered a constant 'digital ticking' noise running in the background. It stops when loading another another preset and then reappears. It's also there if the bypass button is pressed
      Here is a clip – https://www.dropbox.com/s/16wijed50dsex1r/eventide%20noise.mp3?dl=0
      Any idea what might be the problem?
      Thanks in advance
    • #127487
      Hard to know from. a distance.
      Is it on all channels ?
      On analog and digital ?
      Does it. change if you vary any of the gain settings ?
      If you run a reverb, is there reverb on the clocks ?
