DSP 7500 Diatonic shift calibration ?
Home › Forums › Products › Rackmount › DSP 7500 Diatonic shift calibration ?
Viewing 3 reply threads
    • #185620
      woupida
        I am new to Eventide products, I have a 7500 to test wih my guitar  effects.
        The Diatonic presets cannot recognize the notes as they should ! They take a D for a C, E for D etc.
        How can I calibrate the 7500 to recognize the good tunes ? There is a groupe of parameters to calibrate the preset but I cannot see anything wrong.
        Any comments are welcome.
      • #185799
        woupida
          Answer to myself.
          My Eclipse is in tune but not my DSP 7500.
          The only thing I found is to modify the “tune” parameter on “cal” tab. It is possible to set this parameter to -200 cents for my DSP 7500 to be in tune.
          That sounds “fragile”, doesn’t it ?
          If anyone has met a tuning issue please let me know.
        • #187219
          woupida
            Still answering to myself.
            The problem disappeared with modifying the Digital Source to Int (48 kHz. or 44.1 kHz) or to S/PDIF.
            Hope it will be useful for people tho the same issue.
          • #187221
            woupida
              Correction :
              Hope it will be useful for people who encounter the same issue.
