DSP4000 backup memory
Home Forums Products Rackmount DSP4000 backup memory
Viewing 3 reply threads
    • #105276
       Hi ,
      Is there any why to check if the backup memory (U34,BQ4013) is ok?
      Is there any policy after how many years one should replace it?
      My is stamp 9343.
       Peter
    • #116801
       Hi Peter
      what problems are you having with your DSP4000?
    • #116818
      I do not have any problem yet.
      I am doing an inventory of our outboards and other equipment that has backup memory.
      In a AKG ADR68K from 1986 they have a Dallas DS1213 a similar type of
      the one in the DSP4000 and that on has no power left so we lost the
      presets.
      That is what I want to prevent.
       Peter
    • #127857
       Peter
      you *should* backup your preset anyway; you have 2 ways to do this:
      -use Vsig editor on a PC and store them to the hard disk (best)
      -use a PCMCIA card (worst)
      The battery is soldered to the circuit. If the unit works well, the battery id fine.
      When you start having all sort of warning/error messges, and frequent checksum errors messages…then the battery is about to go.
      best
