DSP4000 serial?
Home Forums Products Rackmount DSP4000 serial?
    • #107870
      jlaity
      I have a DSP4000 with version 2.00 software. I am trying to connect it to my Mac through a serial adapter (Keyspan USA-19HS) so that I can use it with VsigX. I have the Serial adapter connected to the 9-pin input of the DSP4000 (there is also an output). I looked through my printed manual but I don't see any mention of serial connections, though I see that others talk about it on this unit. Do I have an old DSP4000, or is there  setting I'm missing?
      Thanks, Jeff
    • #122096
      What looks like a serial socket on an older DSP4000 (which yours is if it has V2.0) is in fact for a (now obsolete) PA bus which will not work with anything modern.
      The MIDI can be used with Vsig, but I don't think this works with VsigX. Sorry – this unit is now almost 20 years old, so support is limited.
    • #122200
      I started working on vSigX because of the lack of serial connection on my GTR4000.  Version 2, when I get back to it, will have both serial and MIDI…
