Last night I was checking out the programs in my DSP7000. When I got to the end of the multieffects bank (bank 27) I loaded the program "5th Place". After the program was loaded, there was no audio output (I was using the analog outs) I then loaded several other programs with the same results…. no audio output. I had to shut off the DSP and power it back on to correct the problem…
Is this a common fault? bug? fluke?… any ideas on what causes this?. I'm running the DSP at 48khz and it's my understanding that all the programs should work at this setting…
Thanks
