DSP7000 Update Question
Home Forums Products Rackmount DSP7000 Update Question
Viewing 6 reply threads
    • #106823
      glennfin
      Hi;
      I just bought a DSP7000 and it's on the way to me Big Smile
      If I need to update the OS to the latest 3.0, can this be done the same way the Eclipse is updated? using a memory card?.
      I'm really looking forward to adding the DSP7000 to my studio guitar rack (right above the Eclipse that's already there! Cool )
    • #119863
      glennfin:
      Not really, because the DSP7000 doesn't support Compact Flash. As a result, the serial approach is the only one you can use.
    • #119865
      glennfin
      Hi Nick;
      What about using a PCMCIA to compact flash adapter? That works in another piece of gear in my studio.. (Roland V-Synth XT)
      Thanks
    • #119866
      glennfin
      What about just a pcmcia memory card? My laptop has a PCMCIA slot, if I can transfer the OS files to a card would that work?
    • #131044
      IDeangelis
      Hi Glenn
      as Nick says, the 7000 does not use any type of card (PCMCIA or CF) for OS updates.
      The only method is using a serial cable with our Oupdate application for Windows PC.
      all the best
      I
    • #131046
      glennfin
      I see, ok, thanks.
      PC's with serial ports are getting hard to find these days!. Do you know if the Oupdate application will work with a USB to serial adapter?
      Thanks for the help! I really appreciate it!
    • #131047
      IDeangelis
      Actually many current PCs motherboards have a serial connector on them. It just needs a COM port on a PCI panel to be connected there.
      Anyway, yes, Serial to USB adapters work fine with Eventides.
      all the best
      I
