Home › Forums › Products › Stompboxes › Dual delay on h9 only produces one delay, why?
- This topic has 6 replies, 2 voices, and was last updated 2 years, 11 months ago by
Chalky.
July 30, 2023 at 11:31 am #172784
I’m trying to set up my take echo so that I get a deal delay 1375 and one at 500 ms, but only one of them actually comes out through my Rig. I’m setting up in mono. I assume that I don’t have to have a stereo rig to take advantage of the dusl delay … surely?!
July 30, 2023 at 11:38 am #172785
Hi Chalky,
Can you provide a little more insight into your signal routing? Are you using the H90 straight into the amp or do you have it connected to the amps effects loop?
July 30, 2023 at 11:56 am #172786
Hi Joe, Gtr to h9 mono in / mono out (I have tried both inputs) to Toneking Imperial. I have delay A at 375 and delay B at 500 but when I try to adjust parameters on the H9 Control I see that delay A is redundant, and only delay B is audible (if I turn the delay box to the left there is no delay).
July 30, 2023 at 12:01 pm #172787
I’m assuming you’re using the Tape Echo algorithm. Is the Delay Mix control in the middle at A10+B10?
July 30, 2023 at 12:49 pm #172788
July 30, 2023 at 2:41 pm #172790
When you say you’re hooked up in mono, you’re going into IN 1 and coming out of OUT 1, correct? What is the Routing on the H9 set to? System menu > UTILS > ROUTE.
August 4, 2023 at 9:15 am #172891
Hello, sorry, was away a few days back to this … firstly yes to IN 1 and OUT ; secondly ‘routing’ I am not seeing UTILS-ROUTE on my H9 control app on my iPhone… the main tabs are algorithms preset list, pedal in settings … Under settings, drop-down called general settings if I press that I get routine which gives me three options which are normal pre-post and with Dry, this is the only location that I can see any reference to routing.
