Dual Mono inputs/outputs for stompboxes
Home Forums Products Stompboxes Dual Mono inputs/outputs for stompboxes
    • #108790
      faganwilcox
      Hi All, I have 2 seperate instruments i'd like to run through these pedal..
      Pitchfactor > Modfactor > Space
      BUT I would like each channel to be independent and not affect the other. Thus if I plug a keyboard in LEFT and a bass guitar in the RIGHT out the other end I don't want keyboard to leak into the bass channel.
      IS THIS POSSIBLE?
      Cheers.
    • #123473
      Imerkat
      quick answer no. Long answer yes. The Space and the PF have the capability through DualVerb and Diatonic. So if you want true parallel operation your stuck with one algorithm on each. Sorry if this is no help
