Dual Routing
Home › Forums › Products › Stompboxes › Dual Routing
    • #184118
      Blacklist Social
        It’s probably an easy question, but when in Dual Routing, can one be mono and the other stereo?  I want to use one side in the first loop of my PBC 6x in mono and the other in loop 6 in stereo… It seems like this should work as it acts like two separate processors in dual mode.  Thanks for the info
        David
      • #184120
          Yes it can! The algorithms will automatically work in mono or stereo based off of what I/O is connected. There is no further configuration need, just connect your mono path and your stereo path and you’ll be all set.
        • #184121
          Blacklist Social
            Sweet… thanks for the very speedy reply and the awesome products!
