Eclipse 4.01 – Signal leds
Home Forums Products Rackmount Eclipse 4.01 – Signal leds
    • #107885
      bazsa82
      When I updates my Eclipse 3,51 to 4.x when I use MONO1 only the left leds functioned. It's normal?
    • #122136
      If you use MONO1, the Eclipse will only use input 1, so probably the other leds will see no signal.
    • #122137
      bazsa82
      So, from the 4.x version, this functio it's normal.
      ( in the 3.5 version, when I use the MONO 1 or MONO 2, the signal leds are functioned as STEREO…)
      OK, Thanks!
