Eclipse ADAT FX Routing
Home › Forums › Products › Rackmount › Eclipse ADAT FX Routing
    • #115975
      belensky
        Hello, I’m using My eventide Eclipse connceted via ADAT to UAD appolo.
        Can I somehow route FxA and FxB to different stereo ADAT outputs. So my DAW records each effect as separarte stereo track.
      • #155186
          Sorry, no. While the Eclipse has two internal stereo effects, it is essentially a two channel box, so you only get one stereo output.
          This is why on UM p.27, the ADAT options are:
          Thru The selected ADAT channel will carry the same signal that the corresponding ADAT input carried.
          Mute The selected ADAT channel will carry silence.
          Ch 1 The selected ADAT channel will carry the Eclipse’s channel 1 output.
          Ch 2 The selected ADAT channel will carry the Eclipse’s channel 2 output.
        • #155187
          belensky
            this is what i was suspecting. thank you for fast reply.
            BTW, I remeber my previos question about adat/spdf running at 96 you told it’s not possibe.
            Somehow I managed  connect my eclipse at 48k and my sessions at 96, eclipse is clock, and everything is in sync. which is great.
            May I ask other question. is it possible to use midi out exacly same way as midi through. I need to split midi signal to two separate devices, and wondering if i can use MIDI out as my splitter,
