Eclipse and H8000
Home Forums Products Rackmount Eclipse and H8000
Viewing 8 reply threads
    • #106897
      ulfiyya
      Hi there,
      Can i program the presets of Eclipse in H 8000?
      And is that also in serie, parallel an xfade in only one DSP?
    • #120047
      IDeangelis
      Yes you can…IF you know how the Eclipse algorithms are made.
      Series,
      parallel is not a problem.
      Xfade doesn't make sense as you have
      two DSPs so you can:
      -use the other DSP to switch to another
      preset
      -build algorithms in a way that you can internally switch
      between parts of them (from a verb to a chorus, for instance).
      best
      I
    • #120060
      jfcharles
      Some programs in the Eclipse are really clones of some of the Harmonizer algorithms. But for some of them (especially the newest ones), it might take some work to replicate them.
    • #131250
      IDeangelis
      "Some programs in the Eclipse are really clones of some of the Harmonizer
      algorithms"
      not exactly. There are some deep differences.
      best
      I
    • #131398
      zap
      well i thought one simply can't because there is no step modulato as you previously mentioned the 8000 does have.  now i am confused.
    • #131399
      IDeangelis
      the H8000 has 2000 algorithms, Eclipse has 100+. So there are BIG differences.
      A Step Modulator is something you need to create into an algorithm in the H8000. It's is not a system modulation source…like Eclipse has.
      There are no patches using a step modulator on Eclipse has it doesn't have one.
      There are some using it on the H8000.
      best
      I
    • #131512
      zap
      you mean the 7600 right? if not,   i am not sure why you are not comparing only 2 channel processors here.
    • #131517
      IDeangelis
      It's the same for the H7600.
      I
    • #133529
      ulfiyya
      Hi italo,
      I know you had time ago the TC 1210 do you still heave it?
      Wich one is close from eventide and can make the same chorus on Eventide H8000?
      Thank you!
      Greets,
