Eclipse doesn’t respond to sysex
Home Forums Products Rackmount Eclipse doesn’t respond to sysex
Viewing 4 reply threads
    • #106809
      krikroff
      My Eclipse doesn't respond to sysex i sent ! All parameters are set correctly: Sysed ID, Sysex: On, Channel, cables are good and properly connected…
      But yet i receive sysex of the eclipse !
      Sysex <bypass>:
      F0 1C 70 01 01 0F 0F 0F 0F 0F 0D 0F 0F F7
      Not respond …not work !
      Please help me.
    • #119846
      What are you trying to do and what results are you expecting ?
    • #119860
      jfcharles
      Works here like a charm.When I send 240 28 112 1 1 15 15 15 15 15 13 15 15 247, the bypass led is turned on or off.
      What are you using to talk MIDI to the unit? Pedal board? Software? Can you send the sysex string to another piece of software to check it's working?
      J-F
    • #131038
      krikroff
      Forum is back, good news !
      Thank you for your answers (nickrose & jfcharles), i think my problem came from a cable defective, it works great with another device but not with Eclipse. The Eclipse seems very sensitive to the quality of the midi signal. Besides, i think now used a "star connection" with a midi thru-box to avoid losses of a connection "in" -> "thru" -> "in" -> "thru".
      nickrose: i program a "remote control" for the eclipse (C#). is it possible to use the document "Eventide Harmonizer MIDI SysEx Reference Manual, v0.90" ?, this document is update ?
      Thank You very much (and excuse me for my bad English…)
    • #131039
      krikroff
      Thank you very much, please consider this post resolved. Wink
