July 20, 2008 at 9:33 pm #105743
>Hi my name is Pierre-Fran?ois and I am a new ECLIPSE owner.
> Here's my first question – what is the best & most versitle way
> to set up my eclipse in my guitar rack (loops #7 & #8 are available into GCX2) ?> Here is the gear:
> Guitar in to :
> – first, (a feedthru loop) GCX1 > BOSS TU-2 > WHAMMYII > POG > GCB95 > GCX1
> – then, the loop above goes in to a GRX4 : dynacomp > BOSS CS-2 > OD-2 > SD-1
> – the chain above goes into a GCX2 with 6 stompboxes into 6 loops : BIG MUFF > BOSS GE-7 > t.c. DUAL PARAMETRIC EQ > Guyatone ps 102 > t.c. INTEGRATED PREAMP > BOSS FA-1
> – then, the chain above goes (through a Y unbalanced cable) into the GCX1 again. Here, there are 4 "stereo parallel" loops : KORG A3 > LINE6 ECHO PRO > KORG A2 > t.c. M2000
> – & at last, into VOX AC30 (wo FX loop), & Randall CENTURY 3000 (FX loop unusable)
> My second question – I'm stuck concerning the way on how to connect the analog audio inputs & outputs [(XLR or 1/4-inch inputs connectors) ? – both of them ? XLR/jack line cables] of the ECLIPSE ? .
> Thanks in advance!
> P.-F.
July 21, 2008 at 1:14 pm #117690
Hi P.F.
congratulations on your Eventide and welcome to the forums!
The optimal place for a digital fx processor is always between preamp and power amp. In your case there's not much you can do other than use another couple of loops (for stereo) to connect the Eclipse to your gtr amps front inputs. Obviously using distortion from the amp is not recommended.
Eclipse uses 1/4" jacks for unbalanced -10dB instrument levels I/O and XLRs for balanced/unbalanced +4dB line levels I/O. You should use the 1/4" jacks in your system.
You may want to check our technotes out, on the Eventide website, regarding gtr rigs tips and I/O wirings.
Enjoy!
I
July 21, 2008 at 8:57 pm #117694
Oh thanx a lot I,
Your answers are very helpful
Regards,
P.-F.
July 26, 2008 at 3:00 am #128847
Ok, here is what you do, go to suhr guitars and order a line out box(really great priced)….
http://www.suhrguitars.com/tonetools.aspx#lineOut
It's a lil' box that you put between your amp and speaker cab that will give you a line level signal of the sound after the amp and it's 100% safe and sounds killer. Take that line out from and run it into the Eclipse….Run the output of the Eclipse into a solid state power amp and run a wet/dry or wet/dry/wet setup. All those items cheap, and there's no way to better keep your sound intact.
July 26, 2008 at 6:59 pm #128850
Thanx for the tip, Man. That seems a good idea.
Nontheless, I just own 2 amps, & the setup you've suggested needs at least 2 additional amps, so as to use both channels of the ECLIPSE.
That's why, I was thinking the best solution (for my rig) was to simply let the ECLIPSE connected in serie in my FX chain.
P.-F.
July 29, 2008 at 7:23 pm #128856
You can add an fx loop to the Vox…..
July 29, 2008 at 8:21 pm #128858
Really ? How ?
July 29, 2008 at 11:13 pm #128860
You would half to find an amp tech.. Try Ziv at noize labs… http://www.zivnagari.com/
August 9, 2008 at 12:59 am #117747
Will I get a reduced output by 6dB, if I wire the outputs of the ECLIPSE with a balanced XLRs to unbalanced 1/4" cable ?
Thanx,
P.-F.
August 10, 2008 at 7:57 am #128888
No, you shouldn't get that level attenuation. The manual states :
1/4-inch Analog Audio Outputs
These analog outputs accept balanced 1/4-inch connectors. The sleeve
is ground, the ring is negative phase (cold), and the tip is positive
phase (hot). Using an unbalanced 1/4-inch connector will reduce the
output by 6dB.But if you use the XLRs to unbalanced 1/4" all should be fine.
I
August 10, 2008 at 10:13 pm #128890
O.K., that's noted,
Thank you,
P.-F.
September 7, 2008 at 6:00 am #128996
….and if you add an effect series loop in your vox, use the suhr minimix (line mixer) and set your effects at 100% wet (same like wet/dry system) like this you'll keep the tone of the distortion. Just add an isptechnologies pedal if your using a Boost/Overdrive pedal and your in business!
Can go to the knowledgebase* but obviously a part is missing at the end (about using a line mixer).
*: http://www.eventide.com/AudioDivision/Support/Knowledgebase.aspx
