March 15, 2008 at 8:47 am #105457
Regarding the Eclipse cakewalk instrument definition file download – has
anyone gotten it to work in Sonar 7? BTW: I have loaded v3.5b4 in the Eclipse.I import the definition into a fresh Sonar midi channel, the patch numbers and names show up correctly but no luck changing to the correct program on the box.
For example, selecting Bank 100 patch 117 via Sonar, the Eclipse responds with 'Program Number 17 Not Found'.
Likewise, when I select Bank 200 patch 217, also get #17 Not Found.I futzed around with hacking some edits in the .ini file and managed to get the Eclipse to change programs but they were offset by 100…..Bank 200 patch 216 selected and I get program 116 on the Eclipse. Bank 300 patch 316 selected and program 216 on Eclipse.
I am new to Sonar (using demo version) so am not familiar at all with the proper editing/creation of the definition files.
thanks for any info.
jr -
March 15, 2008 at 9:02 am #117169
Hi JR
the file was an user upload from years ago, very likely supporting an old OS version.
all the best
I
March 20, 2008 at 3:56 am #117195
I got the Eclipse instrument definition to work in Sonar 7 and
can now call up all the presets from within Sonar.When setting up the Eclipse as an instrument in Sonar, you
have several options for choosing a 'Bank Select Method' .
Choose 'Controller 0'.jr
March 20, 2008 at 8:07 am #128286
With ANY MIDI controller, hardware or software:
MIDI bank select messages allow random access to all presets in your Eclipse, unlike MIDI maps which limit the selection to 128 choices. Eclipse receives bank select messages on MIDI continuous controller #0.
For example, to load preset #451, send a MIDI bank select message (continuous controller #0) with a value of 4, followed by a MIDI program change message with a value of 51. To load preset 13, send a MIDI bank select message (continuous controller #0) with a value of 4, followed by a MIDI program change mes-
sage with a value of 13.best
I
March 20, 2008 at 9:30 am #128288
o.k.
Thanks for the extra info….Your explanation clears up a few
things for me.hmmmm…I can see a project
if I find the time….instrument definition
for the H8000!!jr
