Eclipse – issue trying to add second algo
Home Forums Products Rackmount Eclipse – issue trying to add second algo
    • #168257
      Sorbz62
        I have my Eclipse in a guitar rack being fed Mono from the preamp and out stereo.
        I have an issue where I cannot add a second algo/ effect into the fxb slot. It always says “Cannot add algorithm because of current sample rate”. What doe Athos mean and how do I solve it?
        Maybe I’m doing something wrong, so please could someone easily explain the process for adding a second algo to a preset with only one in the FXA slot. I’m getting frustrated now.
      • #168259
        Sorbz62
          Does this mean*
        • #168260
            Using higher sample rates on the Eclipse will disable some Programs, it sounds like your unit is set to use a higher sample rate. Go to Setup > Dig-In > Clock to change this to 44.1kHz or 48kHz and that should allow you to add an additional algorithm.
            More information can be found on page 25 of the user guide: https://s3.amazonaws.com/com.eventide.downloads/Product+Manuals/EclipseUserManual.pdf
