Eclipse knob wiggling a little.. normal?
Home Forums Products Rackmount Eclipse knob wiggling a little.. normal?
Viewing 3 reply threads
    • #114703
      markiv2290
      Gents,
      I just acquired an Eclipse, used and in good shape, from the original owner.
      The rotary knob has a little wiggle. A little over 1/64″ front-to-back and maybe a little more when tilting it off axis.
      It turns freely and remains centered as it turns. So I removed the two 1/16 allen screws to check the encoder shaft. It has a little play, which translates to the wiggling in the knob.
      Is this normal and/or like that from the factory? Or maybe it’s due to wear, over time?
    • #149015
      I would guess that it is wear ove r time, or maybe the knob has been banged.
      If the control is operating normally I would suggest that you ignore it. A replacement part would not be expensive, but would be a fiddle to change.
    • #149017
      markiv2290
      I have not opened the unit.
      How is the encoder mounted inside? From pictures I found online, it seems to be hidden behind a PCB. Removing that PCBA should not be too complicated, but is the encoder soldered on that PCB ? Hopefully not… direct-mount controls pots/encoders/switches are not the best for maintenance.
    • #149019
      It is indeed soldered. And, you have to take the front panel off and remove the PCB from it to get to the encoder.
      Like I said, fiddly.
      • #149035
        markiv2290
        Is it soldered on its own daugtherboard ?
        If so maybe the daugther board can be replaced. Unless its common with the display or else…
