Eclipse: Max nr of ‘patchings’
Home Forums Products Rackmount Eclipse: Max nr of ‘patchings’
Viewing 0 reply threads
    • #116324
      Hi, new eclipse owner here. I’m enjorying controlling and modulating its parameters externally, either by a
      doepfer drehbank, or by using external midi-lfo’s. However, the maximum number of ‘patches’, i.e. connections
      between eg ext1-ext16 or lfo#1, seem to be rather limited, and moreover seem to vary with the algorithm –
      using the m_bandtaps, I can only set up 7 patches, after which I get a ‘all connections in use’
       – for some other algorithms (plex I think) I can get up to 11. Is this normal? Any trick to maximize the nr of patches?
      Thanks
