eclipse message error
Home › Forums › Products › Rackmount › eclipse message error
Viewing 21 reply threads
    • #108810
      kolyma
        I'm Gus from Italy
        When I turn on my eclipse , appears on the display the following message:
        1) INTERNAL MEMORY CHECKSUM ERROR
        press any key
        and then the eclipse works normally.
        Please somebody explain me what happen.
        Many thanks
        Gus
      • #123495
          Look under "Fixing and Initializing Internal Memory" on p.53 of the UM.
        • #123496
          badmelonfarmer
            Hi Gus,
            Have you followed the steps on page 53 of the manual that suggests how to fix this?
            (sorry I would cut and paste it in, but I am on my phone)
          • #123498
            badmelonfarmer
              Doh! Beaten again by the good man nick Stick out tongue
            • #134582
                but only by a minute …
              • #134583
                I have the same  thing hapening sometimes.It fixes itself and everything runs smoothly.What is this?
                Also my midi thru seems to not be allowing midi notes to go to a sound module.
                Also midi cc activity invokes the eclipse to program change unexpectedly.
                I have changed the battery.Reloaded the operateing system.
                I am noticeing that the baud rate is still initializing at19200 and the depth 8 and stop bit 1 are not changeable?.Is this correct?
              • #134585
                  Robert Tiffin:
                  Your new battery may be no good. Or, if it runs OK for a while after a battery change, and then goes bad again, you may have a hardware problem that is running down the battery – if so, contact support@eventide.com
                  I suspect that your other problems are symptoms of the main memory issue.
                • #123521
                  kolyma
                    many thanks
                    Gus
                  • #123544
                    wilkinsi
                       The unit recently crashed (muted and locked out all commands) and all I did was reboot. Now I've got the checksum error on bootup and still don't have a memory card.
                    • #134620
                      badmelonfarmer
                        nickrose:
                        Follow the instructions in the User Manual under "Fixing and Initializing Internal Memory." If that fails, follow the instructions under "Fixing Strange Behavior, Freezes, Etc.." If that fails, contact support@eventide.com.
                        If your unit is over about 5 years old, it may need a new battery – contact support@eventide.com.
                      • #134621
                        wilkinsi
                          I don't suppose you know which precise battery it is and whether I can replace it myself?
                        • #134622
                          badmelonfarmer
                            here you go….
                            http://forum.eventide.com/cs/forums/t/5675.aspx
                            BR2330
                            not changed one myself but looks simple enough.
                          • #134624
                            wilkinsi
                              Thanks. Looking into getting a card now.
                            • #134625
                              badmelonfarmer
                                No Problem
                              • #134630
                                wilkinsi
                                  The Eclipse manual mentions nothing about replacing the battery, but the DS7500 says the battery i replaced by a qualified technician whilst the thing is still turned on. So, how do I replace the battery without frying myself or the Eclipse? Angel
                                • #134633
                                    You probably need to keep the power on while replacing the battery if you want to preserve User Programs or Settings. If you don't need this, you can do it with the power off and disconnected.
                                  • #134634
                                    wilkinsi
                                      Ah, cool. I was concerned it might render the Eclipse useless.
                                    • #134647
                                      wilkinsi
                                        Replaced the lithium battery, flashed the internal RAM, then ran the 4.01 update. The closest I get to an explosion is the noise via the i/o when going thru XLR to get to selecting the external DIGIN. Incidentally, the VS2400 is seen as alternating between 44100hz and 44092hz, so I'm leaving that SRC on!
                                      • #134663
                                        wilkinsi
                                          Checksum error came back yesterday. Reloaded V4, crashed. reloaded V4 again. Algorithm error?! Replaced lithium battery again, reloaded V4. Yep, hardware fault. I hope the repair bill doesn't cost much. I'm told it could be capacitors and chips. Few things strike me as odd –
                                          1. Majority of crashing occurs when editing usergroups/saving programs to be flagged by usergroups;
                                          2. Eclipse has crashed a lot more since the lithium battery was replaced a second time.
                                          3. When the screen autodims, it looks like its "strobing" for a few mins.
                                          4. Turning the knobs on the Space when assigning them to MIDI CC and modulating parameters/hot keys sometimes introduces wierd nasty feedback from the Eclipse's audio outputs.
                                        • #134668
                                            If the checksum error came back so soon after changing the battery, this suggests either:
                                            a) a bad battery – try another one.
                                            b) possible software oddity or cosmic ray causing non-battery related checksum error. Clear it and try again.
                                            b) hardware problem on Eclipse causing excess battery current. This is the least desirable option
                                            If there is a bad checksum condition, it is usually harmless, but can cause crashes, etc. Needs to be resolved before looking at what may be symptoms of the same problem.
                                          • #134669
                                            wilkinsi
                                              There are two measures I've taken to possibly avoid another crash.
                                              1) Only save to usergroup 1 or above, avoid using UG 0.
                                              2) Only save programs to CF card, not 0-99.
                                              The unit has settled in that I am not currently getting noise from the outputs when I turn knobs on the MIDI connected Space pedal, nor am I getting any more checksum errors or crashes. I've no idea as to why the display strobes when dimmed. I usually disable the dimmer, although this time have left it enabled. I try to keep my gear for as long as possible up to the point where I can't use functions I need. The Eclipse is one of those things I like using a lot. It can be very addictive.
                                            • #134757
                                              wilkinsi
                                                Well, it lasted 20 days without the checksum error til today. That's a world record for me.
