September 25, 2010 at 3:15 am #107283DBurrisMember
According to the manual:
- Memories 0 – 99 are internal user memories.
- Memories 100 – 199 are presets indicating the different algorithms.
- Memories 200 – 499 more complex programs based on the algorithms.
- Memories 500 – 999 user memories on external flash card.
However, I notice that the 4.01 firmware includes presets in the 800 – 960 range that are stored in the internal memory.
What memory numbers now represent the memories stored on the external flash card?
September 26, 2010 at 1:28 am #120787
As you will have guessed, we ran out of numbers. Too many presets. Sorry.
500-999 still work as flash card numbers. But, for obvious reasons, we would recommend that you use the numbers closer to 500,
September 26, 2010 at 9:02 pm #120792DBurrisMember
Thanks for the prompt reply!
For clarification purposes, are these preset numbers how off limits or can I still use them? If I do use them, can the unit distinguish between external and internal by other means.
Currently I'm using a 128M flash card, which is seemingly way overkill for the amount of presets I can use. Is there any way a future point release can expand the number of external slots available or is this feature so embedded in the design that it would be a large effort?
I'm using this unit for live performances so it would be useful to be able to move presets in and out of internal memory as needed for individual shows. Obviously I can still do this, but with current limitation of presets and no segmentation/partitioning of the external flash, it seems somwhat limiting and a limitation of otherwise huge flash cards that I've outgrown for photgraphy work.
On another note, is there any way for me to override the "factory preset" designation on some of the presets that are essentially built upon the same algorithms while continuing to protect the ones I feel are more useful.
Do you have recommended procedures that have worked for other customers for shuffling presets between an external computer and/or external flash card(s) and the internal memory?
The work that has been put into the starting presets is impressive, but I believe many of them need some tweaking for my use.
September 27, 2010 at 3:14 pm #131999
DBurris:
You can still use them, but may confuse yourself – I would suggest that you don't. It is possible that MIDI program loading may go astray if you have two presets with the same number.
DBurris:
Obviously anything is possible, but it is unlikely, as the current number seems enough for most people.
DBurris:
No. These are set in stone so as to protect them from changes.
DBurris:
Using CF cards is probably the easiest.
