eclipse problem to update to 3 to 3.51
Home Forums Products Rackmount eclipse problem to update to 3 to 3.51
Viewing 6 reply threads
    • #107670
      hi
      difficult to upgrade my eclipse 3  to version 3.51
      i have a transcend card 4go
      and when i press the 1 button i read loading romprog.exe from card and after 3 second the eclipse shut down
      but the button tap is green…………….sometimes………………
      boot version is 1.21
      so what can i do to fix this problem?
      jp
    • #121625
        My guess is that your card is formatted as FAT32, which older versions of Eclipse cannot read. You will need to reformat it as FAT or FAT16 – this will probably not be possible on a 4G card, in which case you will need to find a smaller one, or use the serial download approach (PC only).
      • #121838
        badmelonfarmer
          I think Nick made a typo … he means you need to format it with FAT or FAT16 and not FAT32.
          (not trying to me a smartass… just trying to help Embarrassed)
        • #133040
            Mistake, what mistake ? I have powers that ordinary mortals do not possess…
          • #133056
            badmelonfarmer
              LOL nicely done Wink
              Just got a card and updated from 3.1 to 3.51 then to 4.01 successfully
              YAY! now to figure out how to map the TimeFactor repeat function to a midi CC…..Geeked
            • #133063
              i find the solution i get a very old flash card a memup 128mo and it works!
               i can upgrade whith this one my eclipse and my H8000…………..
              ouf
              thank for the support
            • #133067
              badmelonfarmer
                …and an H8000…..I am very jelous!
                I just got a 4GB Sandisk Ultra card and formatted it in Windows with "FAT" this worked fine to upgrade from 3.1 to 3.51 then from 3.5.1 to 4.01
