Eclipse settings – Midi pedal program changes…
Home Forums Products Rackmount Eclipse settings – Midi pedal program changes…
Viewing 3 reply threads
    • #106197
      bazsa82
      I would like use Eclipe with Rolls MP128 midi Buddy Pedal.
      It's working, but between only 100 and 128. How it is possible to portray it, that between 1 and 99 control?
      Best Regards!
      Balazs
    • #118543
      IDeangelis
       Hi Balazs
      Eclipse uses 3 different MIDI Maps to patch program changes to presets.
      MIDI Maps can be choosen (and programmed) under SETUP > MAPS.
      Eclipse presets are divided as follows:
      0>99 user memory
      100>499 factory algorithms and presets
      500> 999 user memory on Compact Flash Card ONLY!
      The 3 maps work as follows:
      Map 1 Program change numbers 1-100 select factory programs 100-199
      Map 2 Program change numbers 1-100 select user programs 0-99
      Map 3 Program change numbers 1-100 select card programs 500-599
      Is this helping you?
      best
      I
    • #118545
      bazsa82
      Thanks So Much!!! I don't found in manual.
      Best Regards!!
      Balazs Cserta
    • #129689
      IDeangelis
       Balazs
      Idea
      you may want to check page 29 in the User Manual, under Loading Programs from MIDI and Using MIDI Maps .
      cheers
      I
