Eclipse V 4.01
Home Forums Administrivia Website Discussion Eclipse V 4.01
    • #115958
      I’ve just had the following message on start up of my Eclipse  “internal checksum error, press any key to continue”  is there a fix for that ? After I press any key the unit works as it should so I’m not panicking about it, but I would like to stop it appearing every time I turn it on..!! any help would be appreciated.
    • #155123
        Hi there, you may have better luck in the rackmount forum where the devs will be more likely to see your post, after some quick research I found this thread which may be helpful to you – https://www.eventideaudio.com/community/forum/rackmount/internal-checksum-error-v4-eclipse
