Eclipse v4 Spill Over
Home Forums Products Rackmount Eclipse v4 Spill Over
Viewing 3 reply threads
    • #188147
      depressor
        Hi, I have the Eclipse v4 and I would like to create a spill over effect between some preset changing. Has the Eclipse got a spill over mode?
        Thank you
      • #188155
          There is no spillover when loading different Programs. You have FX A and FX B within a Program, so you could build a program in a way where you bypass/activate the A/B effects to achieve something similar to spillover.
          The xfade routing mode would also be a good option to explore. See page 38 of the manual: https://s3.amazonaws.com/com.eventide.downloads/Product+Manuals/EclipseUserManual.pdf
          Your best option for an FX processor with true spillover would be the H90. It can achieve a lot of the same things that the Eclipse can do.
        • #188159
          depressor
            Thank you for your support. I have the H90 too, I use it in my pedalboard and it is a wonderful powerful device. The Eclipse is in my rack system. I love my Eclipse and I think that for some reasons it is better than the H90, but for other reasons the H90 is better than the Eclipse. The H90 has new algorithms that the Eclipse hasn’t got and viceversa. Which is your opinion? Do you think that the Eclipse is an old outdate unit? I think that Eclipse has a very good depth of sound in its algorithms. Thank you
          • #188207
              Hi again,
              To clarify, I think it is great to have both an Eclipse and an H90, they each have their own purpose. I would just suggest if you require spillover for a certain application, the H90 will perform better there.
