Eclipse Version 4.0.9
Home › Forums › Products › Rackmount › Eclipse Version 4.0.9
Viewing 4 reply threads
    • #115121
      musikproduzent
        I’m an owner of a new Eclipse that show Version 4.0.9 during startup. What are the technical differences to 4.0.1? For example my CF-Card (16MB SanDisk SDCFB) shows preset numbers beyond 1000. Is there a issue in the SW? Is it possible to adress presets above 999? The manual says CF-Cards >2GB make problems. Perhaps the newer Version 4.0.9 allows bigger CF-Cards.
      • #150868
          There are no significant differences between 4.0x versions – the numbering changes are to identify builds to cover various manufacturing situations.
          3.0 to 4.0 is a big change, 3.0 to 3.5 is a significant change, 3.0 to 3.1 is a small change. 4.0.1 to 4.0.9 is an insignificant change.
          I won't be able to get the information on the CF cards until the New Year, so will answer them then if someone else has not.
        • #150955
            Apologies for delay in replying.
            1) Not sure how you see presets beyond 1000 – this should not be possible unless you hand edited the card. Any idea what got you to this point ?
            2) It should not be possible to access presets beyond 999. We feel that 100 user presets and an extra 300 on a card is plenty.
            3) V4.0 allows the use of cards beyond 2G. There will still be an (unspecified) upper limit, so try and use small cards when possible.
          • #168710
            dedovstas
              Hi! If it still matters for someone, I also can access preset numbers over 1000. But i never tried to save there something. Version number 4.10. and an older unit with the v4.01. The cards were initially not readable, but I discovered a brutal method to formate them. You insert a card into the slot, but w/o contacting the pins. Then you press „format“ and push the card into the slot immidiately. It worked with three different cards sofar. But you have to be quick.
            • #168910
              dedovstas
                Udate to my previous post. I tried to save a preset in a slot above Nr. 1000. I didn’t work.
