Eclipse won’t come out of bypass mode
Home Forums Products Rackmount Eclipse won’t come out of bypass mode
Viewing 3 reply threads
    • #106569
      jimmywhip
      Just received Eclipse today. Put it in guitar rack, first problem was OS wasn't loading? So I held setup button down while restarting & that seem to fix that. However, it will not come out of bypass mode. I took a quick look through the manual and didn't see reference to this problem.
      I just wanted to plug n play today without doing major research yet. I am thinking this can't be correct? Maybe I got a lemon? It shouldn't be a difficult ordeal to plug n play.
      Help anyone?
      Thanks…………….
    • #119326
      IDeangelis
      Hi Jimmy
      which OS version is running on this unit?
      I
    • #119328
      jimmywhip
      version 4.0
    • #119329
      IDeangelis
      You can try a full reinit by pressing and holding the "8" key at power on. Press the YES key on prompt. If that doesn't help. You may need to contact support@eventide.com for servicing the unit.
      Good luck!
      I
