Hello!
I've been using the demo to see how it jives with Renoise. I'm noticing a lot of weird quirks around the plugin. I noticed that Renoise isnt a supported DAW so that's probably why, but when exporting a track, it seems to cut out the audio completely and only every once in a while is an export successful.
On one occassion the wav file was fine until half way through the track, when everything went quiet. haha
Maybe I'm doing something wrong but I notice it more when using DirectSound drivers but it also happens less frequently with ASIO and ASIO4all.
Am I the only one seeing this?
WIN 10 / Renoise / Saffire Pro 14 audio
That's super weird, but as you say, we don't test against Renoise by default. I'll try to grab a demo of it and try it. Have you had a similar problem with any other Eventide plug-ins? Do you have a similar problem with EQuivocate?
Thanks,
Dan
