April 2, 2020 at 5:11 pm #115846
Hi, I’m just diving in and want to explore the presets but the Preset Selector is empty. When I click Load, it’s looking in: HD Root/ Music/NewfangledAudio/EQivocate but these folders are all empty.
I do see that the presets are available at their proper location, according to the manual, User¿/Music/Newfangled Audio/EQuivocate/Preset but when I navigate to this folder and select a preset i can only select one at a time and the Preset Selector doesn’t remember to keep looking here. It goes back to the HD root location each time. It makes for some slow going.
Is there a way to edit where the bundle’s plug-ins look for their presets, so they work as intended?
I wonder if this is because I upgraded from “Newfangled-EQuivocate-1.0.6-osx-installer”? I’m using Reason 10 on OSX Mojave 10.14.2.
April 4, 2020 at 6:52 pm #154505
Oh, wild. Can you contact support at newfangledaudio.com? I probably need to sort out what's going on with your setup. The change to ~/Music is new, and I don't know why it's not working for you.
Dan
April 7, 2020 at 10:58 am #154536
Workaround, for the forum. I simply moved the presets to the location Elevate was looking for, in Mac OS Finder, and am easily using the presets, now.
April 5, 2020 at 3:55 am #154510DGillespie wrote:
Oh, wild. Can you contact support at newfangledaudio.com? I probably need to sort out what’s going on with your setup. The change to ~/Music is new, and I don’t know why it’s not working for you.
Dan
OK. Done. Thanks!
Thanks, that’sa good workaround. I still want to figure out why it’s pointing to the wrong directory on your machine.
OK. I’ll be here.
