Elevate Mastering Bundle – Does not include Limiter?
Home Forums Products Plug-Ins Elevate Mastering Bundle – Does not include Limiter?
Viewing 3 reply threads
    • #189306
      jcaddy222
        Hey all- I just picked up the Elevate Mastering bundle and after installation noticed that I don’t have the Elevate limiter anywhere in my DAW. I’ve reinstalled, rebooted, etc. No luck.
        It should be included in the Mastering Bundle, correct?
        Windows 11 / Ableton Live / Reaper / Wavelab 12
        Thank you in advance.
        J
      • #189313
          Just to confirm, when you search for the plug-in in your DAW you see Newfangled Saturate/EQuivocate/Punctuate but Newfangled Elevate does not show up?
          • #189318
            jcaddy222
              That is correct. I see three plugins but not Elevate (limiter) plugin. I’ve uninstalled it a few times, deactivated the license in iLok, reactivated it, etc. No luck.
          • #189319
            jcaddy222
              I just tried it in Reaper and it’s working fine there. I can see it.
              Ableton is not showing up by default for whatever reason.
            • #189320
              jcaddy222
                Got it, I had to manually move the vst3 file from the Newfangled audio folder, into the main VST3 folder for it to show up.
