Elevate not available in Wavelab Pro 10
Home › Forums › Products › Plug-Ins › Elevate not available in Wavelab Pro 10
    • #115639
      2rs
        I just purchased the Elevate bundle for use in Wavelab Pro 10 with Windows 10.
        When selecting/loading plugins only EQuivocate, Punctuate and Saturate are visible. Elevate is not to be found.
        Is it me and my system or is there an issue with Elevate and Wavelab Pro 10?
      • #153372
        DGillespie
          Hi 2rs,
          We haven't heard anything about this particular problem, but there were some UI issues with Elevate a little while back that were related to Wavelab.  These were fixed with a Wavelab update a while back, can you make sure you've installed the latest Wavelab, then go to Add/Remove Programs and uninstall Newfangled Audio Elevate, then re-install Elevate, but this time choose only the 64 bit version.
          If that doesn't work, you can contact support at newfangledaudio dot com and let me know.
          Thanks,
          Dan
        • #153411
          2rs
            Hi 2rs,
            We haven’t heard anything about this particular problem, but there were some UI issues with Elevate a little while back that were related to Wavelab.  These were fixed with a Wavelab update a while back, can you make sure you’ve installed the latest Wavelab, then go to Add/Remove Programs and uninstall Newfangled Audio Elevate, then re-install Elevate, but this time choose only the 64 bit version.
            If that doesn’t work, you can contact support at newfangledaudio dot com and let me know.
            Thanks,
            Dan
            Thank you,
            Removing and reinstalling, only 64-bit VST3 solved it.
          • #153412
            2rs
              Hi 2rs,
              Thanks,
              Dan
              Thank you,
              Removing previous installation and rinstalling only 64-bit VSt3 worked.
