October 6, 2017 at 2:46 pm #114397Gerhard RaichleParticipant
in Magix Sequoia, Elevate seems to output mono from a stereo track. Tried in Inserts, Busses. Works as expected in Studio One on the same machine. Also, Equivocate works in Sequoia.
Gerhard
October 7, 2017 at 12:36 am #147366
Hi Gerhard, I've not tested it in Sequoia. Do you mean that it shows up with only one output? Or that it outputs on only the left channel? Or that it both output channels are the same, even when the inputs are different?
Also, are you on Mac or Windows, and AU, VST2, or VST3?
Thanks,
Dan
October 7, 2017 at 9:44 am #147367Gerhard RaichleParticipant
Hi Dan,
sorry, forgot to mention: Sequoia ist Windows only, my system: Windows 10, Intel i7, 64 bit.
Did some tests, VST3 / 64bit and VST2 / 64 bit, with Pink Noise stereo, left channel only, right channel only
VST3 sums both inputs to mono, output channels L/R carry the same signal
VST2 works as expected, no summing.
Hope this helps,
Gerhard
October 8, 2017 at 4:50 pm #147369pierrejacquotParticipant
Hi gentlemen
I also run a Sequoia 13 & 14 version on Windows 10 64 I experienced exactly the same issue. Elevate appears (and sounds) as a mono plug-in
Only one single mono baregraph input and output on stereo busses. is there a way to solve this?
Thanks in advance
Pierre
Gerhard Raichle wrote:Hi,
Gerhard
October 9, 2017 at 1:33 am #147371
Hi Guys,
It turns out I released the VST3 version without enough testing. However, I've just isolated and fixed the problem. I expect to release it tomorrow or Tuesday at the latest. In the mean time, VST2 should work fine.
Dan
