October 17, 2017 at 3:36 pm #114421
Using Samplitude Pro X3 Suite with Evevate Causes Samplitude Pro X3 Siote Demo to be Overloaded Changing Efx_comp to Evevate in Mixer.
October 17, 2017 at 9:26 pm #147448
Hi JesusSheep,
Do you mean that it is clipping the output, or that it is using too much CPU?
Do you have it on the final master output, or on a buss output?
October 23, 2017 at 4:59 pm #147481
Buss In Samplitude And Reaper
Over Loaded Dsp only in Samplitude.
October 24, 2017 at 12:28 am #147489
We're working on inter-sample peak suppression in Elevate, which might be what's causing your meters in Samplitude to read high. However, that's crazy high, what are the output peak meters in Elevate reading?
October 26, 2017 at 12:41 am #147507
Top Inless i reduce the imput. Rquivocate does not have same problem.
October 26, 2017 at 12:42 am #147508
I put in an application for Educational Discount what is the progress?
October 26, 2017 at 9:27 pm #147514
Any Decisions om my application ?
Think it has been more that 48 hrs.
What name was it under? I don't think we've seen anything. You can also email support@eventide.com if you don't feel comfortable sharing here.
