Elevate Plugin does not load Ableton10
Home Forums Products Plug-Ins Elevate Plugin does not load Ableton10
    • #114950
      bjacobs
        I’ve installed the Elevate master bundle. Saturate, EQ, and Punctuate all show up. However, Elevate does not. What could be wrong? I am using VST2 on Ableton10 in Windows
      • #150135
        DGillespie
          bjacobs wrote:
          I've installed the Elevate master bundle. Saturate, EQ, and Punctuate all show up. However, Elevate does not. What could be wrong? I am using VST2 on Ableton10 in Windows
          Hi bjacobs,
          I'm not having any problems with the current Elevate (1.5.7) on Windows on Ableton 10.  Can you double check and make sure the Newfangled Elevate.dll is in the VST folder that Ableton is scanning?
          Thanks,
          Dan
          • #150137
            bjacobs
              DGillespie wrote:
              Hi bjacobs,
              I’m not having any problems with the current Elevate (1.5.7) on Windows on Ableton 10.  Can you double check and make sure the Newfangled Elevate.dll is in the VST folder that Ableton is scanning?
              Thanks,
              Dan
              Hi Dan,
              I can verify that .dll is in the folder. And I can verify that I am on 1.5.7. The only thing I haven’t tried is restarting my machine, which I can try when Im home for work. If that doesn’t work are there any logs or anything I can send to you guys?
            • #150139
              DGillespie
                bjacobs wrote:
                Hi Dan,
                I can verify that .dll is in the folder. And I can verify that I am on 1.5.7. The only thing I haven't tried is restarting my machine, which I can try when Im home for work. If that doesn't work are there any logs or anything I can send to you guys?
                That's super weird.  When you installed, did you just choose the normal install options?  Can you email me you iLok.com account name?  (You can email it to support at newfangledaudio dot com)
                Dan
