emote as plugin disconnected in ableton live
Home Forums Products Rackmount emote as plugin disconnected in ableton live
Viewing 4 reply threads
    • #172328
      javartin
        Hi, I tried to use emote as plugin in ableton live, when I open the plugin, the status shows “disconnected”; what’s wrong !?
      • #172329
          In this Device view, you can either turn auto-connect on, or you can click the button above the H9000 icon to connect it. Does that work?
        • #172331
          javartin
            Hi, auto-connect is on but still disconnected ……plugin
          • #172333
              Thanks for the screen shot. Have you tried toggling auto connect on and off? Have you tried clicking the other “connect” button?
              You may try restarting the H9000 and your computer or DAW. Or you may have to do some network/connection troubleshooting if you aren’t able to connect in standalone mode either.
            • #172334
              javartin
                I re-started pc and ableton live and IT WORKED !! Thanks !! But this time the H9K took as much as twice time to display the session view on the front LCD panel (about 4:40). It usually took about 2:30……..
