Emote automation
Home › Forums › Products › Rackmount › Emote automation
    • #115774
      joeydego
        If I bring up emote as a vst and assign automation to a parameter in a DAW session, will it change the value on the H9000? In other words, is my H9000 automatable in this way?
      • #154095
        John Baylies
          Yes. You can automate Functions with your DAW, and then you can assign Algorithm parameters to those Functions on the H9000. Keep in mind that there are 8 Functions available per FX chain.
