Emote request: Option to collapse/expand preset list in algo list
Home Forums Products Rackmount Emote request: Option to collapse/expand preset list in algo list
    • #178349
      J20056
        In Emote, I am doing a search for all algos that contain the word “delay”. It works obviously, but for each algo, it displays the full list of presets which is overwhelming. I wish there was a little +/ button to expand/collapse the list of presets under each algo so it would be easier to surf through algos. Unless there is a way?
      • #178353
        Puppeteer
          Yes, in the algorithm view, there is a little number in a white circle next to the algorithm name. If you click it, the presets will be expanded, click it again and it will collapse.
          For delay, you may be better off using the FX Type filter and select delay, rather than searching for delay.  This will keep the presets in collapsible form.
        • #178442
          J20056
            @puppeteer: Thank you, your suggestion works perfectly.
