Emulate double bass bow in H9.
Home Forums Products Stompboxes Emulate double bass bow in H9.
    • #113075
      Paradox
      Hi
      I’m bass player. I’m looking for an effect which emulates the double bass bow sound. Can you suggest to me some configuration? I’ve worked around synth algo without no success. Many thanks, bye!
      Dario
    • #141756
      I put up some presets in a “Strings” thread that might be of use.  Often, I run my guitar through a Whammy or H910/H949 algorithm upstream, so you may have to tweak them for bass input.  There are adjustments built-in to the expression pedal settings.
      https://www.eventideaudio.com/comment/24342#comment-24342
      The first two presets there are ‘ensemble’ effects.  ‘Cello Bow Scrape’ could do the trick.  Lower the RISE time for a faster attack.  The HotSwitch setting really exaggerates the effect.  The ‘Pizzicato String’ preset would be closer to a finger-plucked sound.
