Emulating Eventide H/W with Anthology Suite
Home Forums Products Plug-Ins Emulating Eventide H/W with Anthology Suite
Viewing 3 reply threads
    • #115573
      wafa12
      I am trying to emulate the “Galaxy Borders” preset from the DSP7000 Unit using Anthology Suite Plugs. As seen here: https://youtu.be/tVzltQd6-Nw?t=96
      Any idea what algorithms were used, and how ?
      It seems to use delay, reverse (or volume ramp?), pitch, and reverb.
      I  came fairly close  using H949, quadravox, and black hole.  I found H949 has reverse, but does’nt have a long enough delay time to repeat in the same way.
      Currently trying to patch a delay with volume ramp modulation on H3000 factory but havent worked it out.
      That hardware sounds so damn nice.
      Release the secret sauce!
    • #152994
      wafa12
      from the manual : EQ > reverse shifters(10 sec) > verb.
      That explains it.
      OK, Eventide, “Reverse Shifter”  VST required!  When??
    • #153113
      wafa12
      Hmmm…..
      It seems Soundtoys offers this in their Crystallizer plug in.. I don’t quite know how or why this effect would be left to anyone other than Eventide to provide in the Anthology X bundle (that I own).
      Answers please Eventide!
    • #153126
      tlongabaugh
      Hi-
      Yes, that's a great sounding preset. Unfortunately, given the limitations of the reverse delaly in H949, getting the needed reverse delay length and sound is currently not possible with Eventide plugins. Taking a look at the Galaxy Borders preset, the routing of that algorithm is also not possible to create with multiple plugins. I will note that the reverb structure of the algorithm seems to be closer to that of UltraReverb than Blackhole.
      We do read and consider all feature and product requests, but I can't comment on the likelihood of a plugin or set of plugins which could recreate this effect at this time.
      Best
      -Tom
