encoder / tap switch behavior
Home › Forums › Products › Stompboxes › encoder / tap switch behavior
Viewing 3 reply threads
    • #105336
      teddybutter
        I encountered some ineffective behavior with the encoder and tap switches… having trouble going into system mode by pressing both, then inside system mode having trouble with the encoder button push not registering.
        is this a hardware or software issue?
        Teddy
      • #116930
        teddybutter
          also… I am using an AUX switch in ALT mode with the new beta software. When I use the bank up function from the aux sometimes it decides to be a tap switch. strange….
          beta 2.0 firmware, Digitech FS3XV
        • #116938
            It sounds as if you have multiple features assigned to the AUX switch, with both FS3 (ALT mode switch 3) and BK+ (bank up) assigned to the same switch.
             If you are in bank mode and you press this switch, you will get both the PLAY mode function (tempo/delay) as well as the bank up. Both will work, but the result may be confusing.
             The solution is to go back to system mode and make sure that you only have one function set to each AUX switch.
          • #116939
               There is a bug in 2.0 beta where the encoder switch has to be pressed twice to enter AUX switch programming mode. This will be fixed in the forthcoming next beta release.
