Envfollow module
Home Forums Products Vsig and Preset Development Envfollow module
Viewing 3 reply threads
    • #171722
      Puppeteer
        Has anyone used the Envfollow or know any factory programs that it is used in?  I’m trying to build an algorithm with it, but I can’t seem to get it to work at all. After an example that I can examine to understand the block.
      • #171756
        jbamberg
          I think you are referring to the envdetect module, right?  This is not used in any of the algorithms on the H9000.  I passed your question to the DSP folks who are the experts in such matters.
        • #171773
          Puppeteer
            Yes, evndetect. Sorry.
            I posted a crash scenario in mattermost with this block. It took out the H9000, Emote and Ableton.
            • #172173
              ndeshpande
                Can you explain what you’re trying to accomplish with envdetect? We might be able to point you in the right direction with a bit of context for what you’re trying to do.
                The quadrature and quadrat2 objects may also be of use to you.
            • #172183
              Puppeteer
                I was trying to use envdetect to create envelope followers in a vocoder.
                Essentially to track the level.of a frequency band of an input signal and then use that to control the gain of a filter on a second input signal. This didn’t work as expected.
                During testing to try to determine what the envdetect was outputting I managed to crash everything badly. I provided a vsig file that causes crashes on matter most.
                If there is a working algorithm using envdetect, I’d be keen to check it out.
