September 20, 2017 at 5:23 am #114368
atscomms
ParticipantWas the offer email premature?
I got a license email but it did not include a lic #. My iLok account shows the plug-in as active but no Lic # is shown.
Equivocate is not even listed on the Eventide plug-in registration page
September 20, 2017 at 1:41 pm #147186
Hi atscomms,
We're not doing serial numbers for this one. But you still have a 100% full license which will be valid for any upgrades. We simply expected a very high volume and wanted to make it as easy as possible for people to get their licenses.
Dan
December 18, 2017 at 8:20 pm #147913
grips777
ParticipantWhen i open Pro tools it says i need to authorize. But when i try it say no it’s not on my ilok. And says it’s not a valid 64bit plug in? How do i get it to work?
December 23, 2017 at 8:26 pm #147972
Hi grips777,
If the license is in your ilok account you can manually authorize the license to your computer using the iLok License Manager. Just log into the iLok License Manager, find the license in your account, and drag it over to your computer on the left.
Thanks,
Dan
December 23, 2017 at 9:55 pm #147974
grips777
ParticipantThere is no activation # and it does not show up in ilok manager. I paid for it i didn’t get it free. It would be alot easyer if you could select in on the register page. after i got it i got the email with the serial# and the license key. But no activation#. And you can’t put letters in the boxes and it’s not enough digits.
December 24, 2017 at 1:32 pm #147979
gkellum
Participantgrips777 wrote:There is no activation # and it does not show up in ilok manager. I paid for it i didn't get it free. It would be alot easyer if you could select in on the register page. after i got it i got the email with the serial# and the license key. But no activation#. And you can't put letters in the boxes and it's not enough digits.
If I'm understanding the problem correctly, you bought EQuivocate online from a store other than eventideaudio.com, and you've been having trouble registering EQuivocate on eventideaudio.com. It doesn't appear in the drop down menu for registering products, and you were having trouble entering your license key.
I just added it to the drop down menu for registering products. I apologize; we made a mistake on our end when we were setting up EQuivocate on the website.
The license key is normally formatted like this: XXXX-XXXX-XXXX. The store you purchased it from should have sent you an email with a serial number like EQ-123456 and a license key in that format. Could you please try registering it again, and if you have any problems please send the email with the serial number and license key you received to our support people so we can check it out together with your iLok user name.
December 24, 2017 at 4:24 pm #147982
grips777
ParticipantHey. i got it to work. Thanks, but i thought i did buy it on the eventide site. But i would have to check my emails to be sure.
December 24, 2017 at 7:04 pm #147984
atscomms
ParticipantI did get Equivocate through a promotional giveaway, so it cannot be registered on the Eventide web site. It is activated in my iLok account, the .dll file is in multiple registered plugin folders (just in case), and it still does not show up in my DAW (Studio One) after a refresh.
December 26, 2017 at 3:50 am #147990
atscomms
ParticipantOK,
I found it in a different EFX folder than I expected, but I did find it.
Thank you
December 29, 2017 at 3:15 am #147998atscomms wrote:
OK,
Thank you
Yes, it will likely be located under a "Newfangled Audio" folder.
January 12, 2018 at 3:16 pm #148087
punksvicious
MemberI have recently switched laptops and trying to register EQuivocate again on the new one but have had no luck. I use Logic Pro and when it opens ilok license manager it just says no licenses available how do I get another license or be able to use it? I did download it for free whilst the offer was still active.
Hi-
It's likely that your activations are still on your old laptop. If you still have access to the old laptop, log in to iLok License Manager and delete them there. Otherwise, please email support@eventide.com and we will sort it out.
-Tom
