Didn’t do this out-of-the-box.I finally got around to programming expression pedal changes, and the first thing I set was the mix(Shimmer). toe is dry, heel is wet, and the numbers on the H9 app seem glitchy when following. The “mix knob” goes backwards too, when moving the pedal.
What’s up? Why did this start, and why is the app reading my changes backwards?
thanks fellow H9 lovers!
