Ernie Ball Exp.
Home Forums Products Stompboxes Ernie Ball Exp.
    • #105525
      Robb
      Does anyone or has anyone used or heard of anyone using an Ernie Ball Volume pedal with TF or MF as an expression pedal? I wish to use a stereo pedal to control both units at the same time. Does anyone know what I would need to do to mod the circuit in order to make it work with these Eventide boxes? Thanks. Robb
    • #117288
      achaput
      We have recently found the Ernie Ball VP Stereo 25K and the VP Junior 25K to be compatible with our stompboxes. The VP Stereo 25K can control a ModFactor and TimeFactor at the same time using the stereo outs, however you can also use a y-cable with compatible expression pedals to accomplish this.
      With the newest TimeFactor software you can also use one expression pedal to control both a ModFactor and TimeFactor via MIDI.
      Alan
    • #117290
      Robb
      Nice one Alan thanks for the swift answer. So I just conect to the Ernie Ball outs? Mono cable? and the MF sees it and optomizes it for best use?
