Error loading Algorithm #0!
Home Forums Products Rackmount Error loading Algorithm #0!
    • #105611
      I get the following error message when I try to load one particular algorithm:
      "Error loading Algorithm #0!"
      I've been using my unit for over 3 years now and never had this problem.
      Any idea why I'm getting this message?
      (I'm using version 3)
      Thanks
      Gerry
    • #117441
       Hi Gerry
      you should try reinitializing the unit to factory defaults, using the full erase/reinit method. It will erase your presets, if you have creted/stored any.
      Power the unit on w/the 8 key pressed & held. Follow the instructions on the display.
      You may also want to upgrade your unit as it must be on a very old OS version. Shortly we'll be releasing V3.5. You need to register your unit and creat an account on our website to get the new OS.
      all the best
