September 7, 2008 at 7:57 pm #105815
I've just got my new Eclipse from American Musical Supply.
I want to copy Preset # 274 to User Preset 01. When I do so, all seems to be fine (I select "Utility", then "Copy" – I select the Preset I want (SRC FROM – SRC TO), etc.
I can copy this preset (no problem), however – when I go to select this Preset at 01, I receive an error message saying it cannot load it.
I initialize my Eclipse to take it back to the Factory settings, and tried this again – no luck, same error message when loading 01.
Can I NOT copy this Preset and Load this Preset to the copy location because of what and where it is originally?
Is there an Error Code index so I can see what the problem is (according to the error code)?
Many thanks for your help.
~ J
September 15, 2008 at 1:49 pm #117852
Hello
I have tried what you describe and get the same result. It's definitely a bug we'll have to look into. Current work_around is to load preset 274 then save it to memory #1. Reload works fine. Thank you for this report.
All the best
Italo
September 15, 2008 at 3:36 pm #117856
Ok, that works. However, when I copy a preset to anywhere in the 1-99 range, my midi controller cannot find it. Here's what I mean:
I have my midi controller set up on the same channel as my Eclipse. The midi controller is able to access the Eclipse and make changes. However, if I tell my midi controller to access Preset #1, it goes to Preset # 101. I'd be happy to work around this by saving the #274 Preset to #101, but the Eclipse will not let me. It will only allow me to SAVE a Preset to # 1- 99.
The COPY function allows you to COPY a preset to ANY preset number, but as you know this does not work with multi-algorithm Presets.
What can I do to gain access (via midi) to Presets 1-99?
Thank you,
Joel
September 15, 2008 at 3:44 pm #129009
Joel
Eclipse uses MIDI Maps. It has 3 of them, fully customizable. You'll find them under SETUP > MAPS.
Factory defaults are:
Map 1 _ ProgChanges 0>127 recall presets 100 > 227
Map 2_ ProgChanges 0>127 recall presets 0 >127
Map 3_ProgChanges 0>127 recall presets 500 and higher (these are stored on a card)
Choose the right Map for you.
best
I
September 15, 2008 at 4:17 pm #129010
Excellent information.
Thank you!
Joel
