errors on H8000fw
Home Forums Products Rackmount errors on H8000fw
    • #105725
      Siem
        I've got a problem with my H8000fw, when I boot it, it'll state the following
        either this: "faulty presets code installed contact factory"
        or this: "a bus error has occurred (e12)"
        "program 0830b6"
        "data ce7bce7d"
        "please write these down and reboot"
        Can I fix this with somesort of keycombo at boot and a reflash or should I send it over?
      • #117644
          This is a generic message
          that can mean many things, both software and hardware. There are various steps
          to take:
          1)
          Hold down the PROGRAM key at the second
          startup screen ? this will blow away the current loaded program, which may be
          causing the problem. If this fails ?
          2)
          Hold down the SETUP key at the second
          startup screen ? this will restore the configuration to factory defaults without
          losing saved programs. If this fails ?
          3)
          Hold down the ?8? key at the second
          startup screen ? this will restore the configuration to factory defaults AND erase all saved programs. If this fails ?
          4)
          Open the top and carefully reseat all socketed
          parts, especially U106, U205. If this fails ?
          5)
          It?s a hardware problem and has to come in
          for service.
