EVE/NET protocol
Home Forums Products Rackmount EVE/NET protocol
Viewing 4 reply threads
    • #116434
      emilm
         I was curious about the EVE/NET protocol and thought it would be an interesting project to make a software or plugin to manage the Eventide units.
        Since it’s not Ethernet it has to be something else, but you can get adapters for UART, SPI and I2C .
        I completely understand if you don’t want to give me info, I don’t expect a proprietary protocol to have “public style” documentation. 🙂
        I thought would be better to ask than to get a used EVE/NET and use a logic analyzer 🙂
      • #157584
          Eve/Net uses CAN (Controller Area Network). a network protocol from the motor industry, running at up to 1Mb/s.
          I'm afraid we have no public documentation of the protocol, but it is pretty straightforward.
          There are USB CAN adaptors available, but it would be a lot of work to use them.
        • #157585
          emilm
            Thanks! that’s really helpful.
            Do you happen to have a pinout from the RJ45, and does the EVE/NET module need to present itself or send a magic byte to be allowed to receive data?
            Or does the display data etc just flow continuously and it’s just pushed onto the CAN bus
            Thanks again! 🙂
          • #157587
              The RJ45 is:
              1) Power+ (24V)
              2) GND
              3) CANH
              4) Power+ (24V)
              5) Power+ (24V)
              6) CANL
              7) GND
              8) GND
              I don't have the details of the protocol, so you will have to work it out yourself. First, get a good book on CAN.
            • #157588
              emilm
                Thanks a lot! The biggest mystery is what the eve/net send from it’s panel, jog wheel and kbobs. I guess the only way is to sniff the communication with wireshark.
