Evenmidi AND USB program at the same time
Home Forums Products Stompboxes Evenmidi AND USB program at the same time
Viewing 3 reply threads
    • #115138
      mdorren
      I would like the program to be up on my screen at the same time that I amusing my Evenmidi with my H9, however I’m told that midi can’t work at the same time as USB.  Here’s the question:
      If I use bluetooth instead of USB will I be able to have both?  The only reason that I want to see the screen is to see the legend of each knob for each patch.
      Thanks in advance,
      Marty
    • #150915
      You should be able to use any two except USB and MIDI.
      There may be priority issues if you use them simultaneously (they weren't designed for that) – you'll have to judge for yourself what (if any) the issues are.
    • #150916
      mistercharlie
      I have the Evenmidi and it works fine with H9 Control and Bluetooth.
      • #150940
        Herr Mosa
        +1
        I sometimes use the ipad as monitor / visual feedback
    • #150920
      mdorren
      Thanks all. I’ll try it this weekend
