EVENTIDE 4000 Guitar inputs.
Home Forums Products Rackmount EVENTIDE 4000 Guitar inputs.
Viewing 3 reply threads
    • #108266
      drevo
      Hi!
      I would like to know if I can connect my guitar in INPUT 1 and INPUT 2 at the same time. And connect my 2 Amps with OUTPUT 1  and OUTPUT 2 ????.Thanx.
    • #122997
      bluegate
      You can connect your guitar to input 1 & 2, and amps to output 1 & 2.
      Don't connect output 1 & 2 together to one source without a mixer.
      But to seperate amps no problem.
      Why would you want to do this?
      Best is to use a pre-amp or the 4000 in an FX loop.
    • #123035
      drevo
      THANX.
      How to use a pre-amp or the 4000 in an FX loop.Can you explain this please?
    • #134142
      bluegate
      You make a chain like this:
      Guitar -> Preamp -> DSP4000 -> Poweramp -> Speaker
      or
      Guitar -> Amp input ->Amp FX send -> DSP4000 input -> DSP4000 output -> FX return -> Amp speaker.
